Hello. New to phorum, need help with ID
I have a feeling 39-7 or 38-15 are very very close radios. 38-15 cause it looks the same, both chassis and dial, and 39-7 since there are pushbuttons.
RE: Hello. New to phorum, need help with ID - by morzh - 09-10-2014, 03:11 PM
RE: Hello. New to phorum, need help with ID - by Azkickn66 - 09-14-2014, 03:39 AM
There are currently 9768 online users. [Complete List]
» 3 Member(s) | 9765 Guest(s)
