Philco 46-1201 (128) Schematic help needed
Go here:
http://philcoradio.com/phorum/showthread.php?tid=215
There you will find a package of 46-1201 information, with all production changes, in zipped PDF format.
Re: Philco 46-1201 (128) Schematic help needed - by Ron Ramirez - 10-17-2008, 05:59 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
