Questions about Philco electrolytic canisters
Look the part numbers up on the philco repair bench, it may have the info on which cap goes to which color. Does the schematic have any info on it? If not you may have to trace each cap through the schematic to match it to the chassis.
RE: Questions about Philco electrolytic canisters - by tab10672 - 09-12-2014, 08:32 PM
There are currently 3687 online users. [Complete List]
» 1 Member(s) | 3686 Guest(s)
