Was working, now trying to burn up!
Removing the tube and not having a problem from there doesnt necessarily mean its the tube, but somewhere in that part of the circuit. Should check the rest of the caps, resistors, etc in that part of circuit. Check the tube with a tube tester also. Then you will have an idea.
Was working, now trying to burn up! - by BenWA - 09-12-2014, 08:43 PM
RE: Was working, now trying to burn up! - by Warren - 09-12-2014, 09:10 PM
RE: Was working, now trying to burn up! - by sam - 09-13-2014, 09:04 AM
RE: Was working, now trying to burn up! - by sam - 09-13-2014, 07:25 PM
RE: Was working, now trying to burn up! - by sam - 09-13-2014, 10:55 PM
RE: Was working, now trying to burn up! - by sam - 09-13-2014, 11:27 PM
There are currently 8919 online users. [Complete List]
» 3 Member(s) | 8916 Guest(s)
