Questions about Philco electrolytic canisters
The philco repair bench search didn't get me anything, and my schematic doesn't show a code either. Guess I'll have to do it the hard way.
Jeff
RE: Questions about Philco electrolytic canisters - by Antiquesole - 09-12-2014, 09:18 PM
There are currently 9469 online users. [Complete List]
» 2 Member(s) | 9467 Guest(s)
