Was working, now trying to burn up!
Threads: 6
City: Tacoma, WA
I pulled both 41s and reinstalled he 7Y4... the dial bulbs half-dim flicker some but I don't hear sizzling and the transformer doesn't seem to get excessively hot.
EDIT: I take that back! It began to sizzle and get hot on the second try.
(This post was last modified: 09-12-2014, 09:24 PM by BenWA.)
RE: Was working, now trying to burn up! - by BenWA - 09-12-2014, 09:22 PM
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 9883 online users. [Complete List] » 2 Member(s) | 9881 Guest(s)
