Was working, now trying to burn up!
I went on the local library's website and found two books and placed them on hold for pickup:
How to repair old-time radios / Clayton L. Hallmark (1979)
Old time radios! : restoration and repair / Joseph J. Carr (1991)
Those should be most helpful, if only for understanding how these old beasts work.
Was working, now trying to burn up! - by BenWA - 09-12-2014, 08:43 PM
RE: Was working, now trying to burn up! - by BenWA - 09-13-2014, 12:38 AM
RE: Was working, now trying to burn up! - by sam - 09-13-2014, 09:04 AM
RE: Was working, now trying to burn up! - by sam - 09-13-2014, 07:25 PM
RE: Was working, now trying to burn up! - by sam - 09-13-2014, 10:55 PM
RE: Was working, now trying to burn up! - by sam - 09-13-2014, 11:27 PM
There are currently 9883 online users. [Complete List]
» 2 Member(s) | 9881 Guest(s)
