40-165 decals
Hi, I'm getting ready to restore a 40-165. Does anyone have a picture that shows the correct decals and placement of decals that they could post or send me? Also does this radio use the same dial cover as the 40-140?
Keith
40-165 decals - by keith49vj3 - 09-13-2014, 07:28 AM
RE: 40-165 decals - by ccomer1955 - 09-13-2014, 12:38 PM
RE: 40-165 decals - by keith49vj3 - 09-13-2014, 06:08 PM
RE: 40-165 decals - by Warren - 09-13-2014, 06:32 PM
RE: 40-165 decals - by keith49vj3 - 09-14-2014, 02:27 PM
RE: 40-165 decals - by Squire - 09-16-2014, 01:23 PM
There are currently 9659 online users. [Complete List]
» 1 Member(s) | 9658 Guest(s)
