116 chassis, loss of reception
Odd, but in the Ant coil can had a slip of news paper which was acting like insulation. Now, I can read part of it. It has something to do with A Charles S. Starr, Henrietta E. Garrett, and $17.000.000.
Etech looked it up in Google, and look at what we found.
http://www.time.com/time/magazine/articl...-2,00.html
My best guess, given the time frame (1932 - 1937), and where this case took place. A Philco employee stuffed this paper into the can for some reason or another?
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
116 chassis, loss of reception - by BDM - 10-04-2008, 10:53 PM
Re: 116 chassis, loss of reception - by BDM - 10-04-2008, 11:50 PM
Re: 116 chassis, loss of reception - by BDM - 10-05-2008, 01:21 AM
Re: 116 chassis, loss of reception - by BDM - 10-05-2008, 01:45 AM
Re: 116 chassis, loss of reception - by exray - 10-05-2008, 07:28 AM
Re: 116 chassis, loss of reception - by mandh - 10-05-2008, 08:35 AM
Re: 116 chassis, loss of reception - by BDM - 10-05-2008, 12:16 PM
Re: 116 chassis, loss of reception - by BDM - 10-17-2008, 01:25 AM
Re: 116 chassis, loss of reception - by BDM - 10-18-2008, 06:35 PM
Re: 116 chassis, loss of reception - by etech - 10-18-2008, 10:55 PM
There are currently 10198 online users. [Complete List]
» 3 Member(s) | 10195 Guest(s)
