Was working, now trying to burn up!
Quote:If your car stalls on the side of the road, you don't just decide to rebuild the entire engine right then and there. I suppose you could.. but why if nothing is wrong except the fuel filter?
Your car didn't start smoking either if it only needed a fuel filter. Also, repairing a car vs an old radio is like comparing apples to oranges but,
OK, Up to you if you wanna take a chance on ruining the transformer and what ever else.. But, Good Luck. Icon_smile
Was working, now trying to burn up! - by BenWA - 09-12-2014, 08:43 PM
RE: Was working, now trying to burn up! - by sam - 09-13-2014, 09:04 AM
RE: Was working, now trying to burn up! - by Warren - 09-13-2014, 06:28 PM
RE: Was working, now trying to burn up! - by sam - 09-13-2014, 07:25 PM
RE: Was working, now trying to burn up! - by sam - 09-13-2014, 10:55 PM
RE: Was working, now trying to burn up! - by sam - 09-13-2014, 11:27 PM
There are currently 9615 online users. [Complete List]
» 3 Member(s) | 9612 Guest(s)
