Was working, now trying to burn up!
I think the misunderstanding was on his end ... but anyhow.
Yes, I am sure a lot of completely clueless people do show up and have no interest in actually learning proper repair and just expect a magic band aid to fix their machines.
Funny I should say it that way. There is what appears to be a piece of thick type of medical tape on top of that one old Zenith electrolytic cap to insulate it from the loose dial indicator panel which is loose due to rotten rubber mounts. But hey, at least someone tried to keep things from shorting out! I wonder if the rotten rubber allowing the mounting bolts to contact chassis frame could also be a problem with it. I will post pics of what I am referring to later on tonight or tomorrow.
Was working, now trying to burn up! - by BenWA - 09-12-2014, 08:43 PM
RE: Was working, now trying to burn up! - by sam - 09-13-2014, 09:04 AM
RE: Was working, now trying to burn up! - by sam - 09-13-2014, 07:25 PM
RE: Was working, now trying to burn up! - by BenWA - 09-13-2014, 09:13 PM
RE: Was working, now trying to burn up! - by sam - 09-13-2014, 10:55 PM
RE: Was working, now trying to burn up! - by sam - 09-13-2014, 11:27 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
There are currently 2667 online users. [Complete List]
» 4 Member(s) | 2663 Guest(s)
AvatarAvatarAvatarAvatar
