37-116x cabinet chassis tube layout sticker (inside)
Then you will need one for the 37-3116 since this is a Canadian version. Unfortunately I don't have one, maybe another Canadian collector does, try the London radio club.
RE: 37-116x cabinet chassis tube layout sticker (inside) - by Arran - 09-14-2014, 03:56 AM
There are currently 7476 online users. [Complete List]
» 3 Member(s) | 7473 Guest(s)
