Someone else just got a Silvertone 45
If you
1. Clean the rat poop,
2. Clean the chassis,
3. Deodorize the rat smell,
4. Exorcise rat ghosts,
5. Count turns AND
6. Mark the directions of the windings (IMPORTANT)
7. self-immol....oh, wait, I need you to bring my cabinets....OK, sacrifice a black chicken, a black she-goat and feed it all to a black cat of my choice.....
Yep, possible.
Pay special attention to 5 and 6.
RE: Someone else just got a Silvertone 45 - by morzh - 09-14-2014, 10:17 AM
There are currently 5768 online users. [Complete List]
» 1 Member(s) | 5767 Guest(s)
