Where is this dial used?
As I posted, the 340's I have seen on RM all have the 14 on the dial. This one is pristine and I am willing to sell it.
Where is this dial used? - by radiodale - 09-14-2014, 09:26 PM
RE: Where is this dial used? - by BenWA - 09-14-2014, 10:08 PM
RE: Where is this dial used? - by OldRestorer - 09-15-2014, 07:06 AM
RE: Where is this dial used? - by radiodale - 09-15-2014, 08:54 AM
RE: Where is this dial used? - by Eric - 09-16-2014, 07:39 PM
RE: Where is this dial used? - by radiodale - 09-16-2014, 08:12 PM
RE: Where is this dial used? - by radiodale - 09-16-2014, 09:51 PM
RE: Where is this dial used? - by Eric - 09-17-2014, 10:12 AM
RE: Where is this dial used? - by radiodale - 09-17-2014, 11:11 AM
There are currently 10530 online users. [Complete List]
» 4 Member(s) | 10526 Guest(s)
AvatarAvatarAvatarAvatar
