ZENITH 7S-363 CONSOLE PARTS
Hey, Nice radio. I tried one of the sites that you guys told me about and I received no answer about the pushbutton shafts. I guess I'll try again. Just curious are the reporduction shafts made of the same fiber board material?
David Regira
ZENITH 7S-363 CONSOLE PARTS - by philcodave - 10-18-2008, 12:26 AM
Re: ZENITH 7S-363 CONSOLE PARTS - by etech - 10-18-2008, 09:34 AM
Re: ZENITH 7S-363 CONSOLE PARTS - by Ron Ramirez - 10-18-2008, 09:54 AM
Re: ZENITH 7S-363 CONSOLE PARTS - by philcodave - 10-18-2008, 01:47 PM
Re: ZENITH 7S-363 CONSOLE PARTS - by etech - 10-21-2008, 07:31 AM
Re: ZENITH 7S-363 CONSOLE PARTS - by philcodave - 10-21-2008, 07:49 PM
Re: ZENITH 7S-363 CONSOLE PARTS - by etech - 10-21-2008, 08:42 PM
Re: ZENITH 7S-363 CONSOLE PARTS - by Jim Berg - 10-30-2008, 10:51 PM
Re: ZENITH 7S-363 CONSOLE PARTS - by philcodave - 10-31-2008, 01:37 PM
