ZENITH 7S-363 CONSOLE PARTS
The shafts that are manufactured by Larry Bordonaro at Antique Radio Knobs are glass epoxy circuit board material. They are much stronger than the old fiber shafts. He will also email an instruction sheet on how to install them. It is a bit tricky.
I'm not sure which ones Alan Jesperson of Great Northern Antiques sells.
Ed
ZENITH 7S-363 CONSOLE PARTS - by philcodave - 10-18-2008, 12:26 AM
Re: ZENITH 7S-363 CONSOLE PARTS - by etech - 10-18-2008, 09:34 AM
Re: ZENITH 7S-363 CONSOLE PARTS - by Ron Ramirez - 10-18-2008, 09:54 AM
Re: ZENITH 7S-363 CONSOLE PARTS - by philcodave - 10-18-2008, 01:47 PM
Re: ZENITH 7S-363 CONSOLE PARTS - by etech - 10-21-2008, 07:31 AM
Re: ZENITH 7S-363 CONSOLE PARTS - by philcodave - 10-21-2008, 07:49 PM
Re: ZENITH 7S-363 CONSOLE PARTS - by etech - 10-21-2008, 08:42 PM
Re: ZENITH 7S-363 CONSOLE PARTS - by Jim Berg - 10-30-2008, 10:51 PM
Re: ZENITH 7S-363 CONSOLE PARTS - by philcodave - 10-31-2008, 01:37 PM
Philco 91 Tuning Condenser
