40-165 decals
I can send you a picture of my 40-160. I think the only difference will be that yours has SW and mine doesn't. The original bezel is much better looking IMO than what's on your Radiobar, but the Radiobar is beautiful anyway!
40-165 decals - by keith49vj3 - 09-13-2014, 07:28 AM
RE: 40-165 decals - by ccomer1955 - 09-13-2014, 12:38 PM
RE: 40-165 decals - by keith49vj3 - 09-13-2014, 06:08 PM
RE: 40-165 decals - by Warren - 09-13-2014, 06:32 PM
RE: 40-165 decals - by keith49vj3 - 09-14-2014, 02:27 PM
RE: 40-165 decals - by Squire - 09-16-2014, 01:23 PM
There are currently 9690 online users. [Complete List]
» 1 Member(s) | 9689 Guest(s)
