40-190 Antenna
No other loop will substitute for the original, unless it is another loop from a 1940 Philco 40-180, 185 or 190. The loop is part of the set's front end and the radio will not function properly without it.
40-190 Antenna - by radiodale - 09-16-2014, 09:14 AM
RE: 40-190 Antenna - by Squire - 09-16-2014, 01:18 PM
RE: 40-190 Antenna - by Ron Ramirez - 09-16-2014, 03:47 PM
RE: 40-190 Antenna - by radiodale - 09-16-2014, 05:55 PM
RE: 40-190 Antenna - by Ron Ramirez - 09-16-2014, 06:35 PM
RE: 40-190 Antenna - by murf - 09-26-2014, 10:18 PM
There are currently 3126 online users. [Complete List]
» 2 Member(s) | 3124 Guest(s)
