Philco Grille Cloth
Willie
That cloth looks nice. Icon_thumbup
Here are some suggestions for Philco cloth that is no longer available, but should be:
1. Pattern #5. Used in the following Philco models:
1935: 38B, 39B, 60B, 66B, 84B (V2), 89B cathedrals; 18B, 32B, 34B, 49B, 66S, 97B, 118B, 144B tombstones; 54C and 59C (V2) table models.
1936: 38B (V1), 60B (V1), 89B (V1), 610B.
[Image: http://i326.photobucket.com/albums/k420/...g~original]
2. Pattern #13. Very similar to what was used in the 45C, 28C, 29CSX table models, possibly others.
3. Pattern #52. Used in Philco 20, Console Grand speaker table, 86, 511 Series consoles.
And finally, here's a neat 1935 pattern that was used in Philco cathedrals, tombstones, and consoles. This pattern was never reproduced by anyone.
(Photo furnished by Jeffrey Goldstein for the Philco Radio Gallery)
Those are my suggestions...
I would also suggest, for the UK Philcos, the pattern in the 2620B I posted in post #5 above.
Now as for the decals. The PHILCO decal as used on UK sets is unique to that region, and is different from the USA fonts. I am not aware of anyone who has ever reproduced that particular decal. There is basically no demand for it over here, for obvious reasons.
Philco Grille Cloth - by HOTWIRE - 09-09-2014, 03:27 PM
RE: Philco Grille Cloth - by Eric Adams - 09-09-2014, 03:52 PM
RE: Philco Grille Cloth - by Ron Ramirez - 09-09-2014, 04:01 PM
RE: Philco Grille Cloth - by HOTWIRE - 09-09-2014, 04:24 PM
RE: Philco Grille Cloth - by Ron Ramirez - 09-09-2014, 04:37 PM
RE: Philco Grille Cloth - by Arran - 09-09-2014, 10:33 PM
RE: Philco Grille Cloth - by OldRestorer - 09-10-2014, 11:55 AM
RE: Philco Grille Cloth - by HOTWIRE - 09-12-2014, 04:49 PM
RE: Philco Grille Cloth - by HOTWIRE - 09-16-2014, 02:33 PM
RE: Philco Grille Cloth - by Ron Ramirez - 09-16-2014, 04:16 PM
RE: Philco Grille Cloth - by HOTWIRE - 09-17-2014, 01:05 PM
RE: Philco Grille Cloth - by HOTWIRE - 01-24-2015, 11:14 AM
There are currently 10350 online users. [Complete List]
» 1 Member(s) | 10349 Guest(s)
