40-190 Antenna
Wow Squire, it really works well. I just happen to have a Terk which usually sits behind my Pioneer receiver which has an AM rod antenna. It does not need to be connected to the Pioneer but I hooked it to terminals 1 and 4 on the Philco and I receive many loud stations now.
Great idea since I repair many Philcos from all over the country and do not want to have them ship the radio, speaker AND antenna.
Thank you,
40-190 Antenna - by radiodale - 09-16-2014, 09:14 AM
RE: 40-190 Antenna - by Squire - 09-16-2014, 01:18 PM
RE: 40-190 Antenna - by Ron Ramirez - 09-16-2014, 03:47 PM
RE: 40-190 Antenna - by radiodale - 09-16-2014, 05:55 PM
RE: 40-190 Antenna - by Ron Ramirez - 09-16-2014, 06:35 PM
RE: 40-190 Antenna - by murf - 09-26-2014, 10:18 PM
There are currently 9936 online users. [Complete List]
» 3 Member(s) | 9933 Guest(s)
