Philco 116x speaker
I just went through this with an old H model. I still haven't ruled out doing it myself, but there is a guy in Ohio, one in New Jersey, one in Utah, and one in Georgia in addition to several smaller shops with no web presence. This forum has a list in the resources section, but the cost will be somewhere between $50-$90 depending on who does the work. Add to that the cost of shipping the speaker both ways.
http://www.philcoradio.com/resourceb.htm
Charlie in San Antonio
Philco 116x speaker - by Ronin61 - 09-16-2014, 10:02 PM
RE: Philco 116x speaker - by ccomer1955 - 09-16-2014, 11:52 PM
RE: Philco 116x speaker - by morzh - 09-17-2014, 07:39 AM
RE: Philco 116x speaker - by Arran - 09-18-2014, 12:11 AM
RE: Philco 116x speaker - by Fred Taylor - 09-18-2014, 07:46 PM
RE: Philco 116x speaker - by Ronin61 - 09-18-2014, 09:31 PM
There are currently 3849 online users. [Complete List]
» 1 Member(s) | 3848 Guest(s)
