I need to identify this radio!
I'm not sure what it is but it was highly unlikely that it left the factory with a set of Dakaware knobs like it has now. The magic eye looks either like someone added it or that it lost an escutcheon, the hole looks too large for a factory job. It also looks like the top was broken off the cabinet, the lines of the inlay don't line up.
I need to identify this radio! - by casanegra - 09-16-2014, 03:59 PM
RE: I need to identify this radio! - by Arran - 09-17-2014, 03:02 AM
RE: I need to identify this radio! - by exray - 09-17-2014, 04:20 AM
RE: I need to identify this radio! - by JimZ - 09-17-2014, 08:41 AM
RE: I need to identify this radio! - by morzh - 09-17-2014, 08:48 AM
RE: I need to identify this radio! - by JimZ - 09-17-2014, 09:36 AM
RE: I need to identify this radio! - by morzh - 09-17-2014, 10:04 AM
RE: I need to identify this radio! - by Joe Rossi - 09-17-2014, 04:47 PM
