Where is this dial used?
Here is a picture of mine if I do this right. Also my dial glass measures 9 3/8
Eric
Where is this dial used? - by radiodale - 09-14-2014, 09:26 PM
RE: Where is this dial used? - by BenWA - 09-14-2014, 10:08 PM
RE: Where is this dial used? - by OldRestorer - 09-15-2014, 07:06 AM
RE: Where is this dial used? - by radiodale - 09-15-2014, 08:54 AM
RE: Where is this dial used? - by Eric - 09-16-2014, 07:39 PM
RE: Where is this dial used? - by radiodale - 09-16-2014, 08:12 PM
RE: Where is this dial used? - by radiodale - 09-16-2014, 09:51 PM
RE: Where is this dial used? - by Eric - 09-17-2014, 10:12 AM
RE: Where is this dial used? - by radiodale - 09-17-2014, 11:11 AM
There are currently 5325 online users. [Complete List]
» 1 Member(s) | 5324 Guest(s)
