Model 531 removing switches
I have a 20s-30s Philco lowboy model 531. I want to get the chassis out but there is a toggle switch and a phono jack that has to be removed from the front panel first. The switch and jack both have round ring nuts with grooves like the edge of a dime. I can't get a grip on them with needle nose pliers cause they're slightly sunken into the brass control panel and i'm afraid i'll scratch the panel. Is there a technique or special tool to remove those nuts safely?
Thanks!
Model 531 removing switches - by Guest - 10-22-2008, 06:44 PM
Re: Model 531 removing switches - by Ron Ramirez - 10-22-2008, 06:58 PM
Re: Model 531 removing switches - by Guest - 10-23-2008, 01:30 AM
There are currently 5726 online users. [Complete List]
» 1 Member(s) | 5725 Guest(s)
