Proper polarity for filter caps in 1936 models
This is one situation in which a non polarized capacitor could be used, if practical to do so. Since it's only 25 volts it would be easier to do then with a typical filter capacitor, more compact and more sizes available to play with.
RE: Proper polarity for filter caps in 1936 models - by Arran - 09-18-2014, 12:04 AM
