Need help restoring my 40-180 - SUCCESS
Threads: 8
City: Central PA
Just for fun, here are the before and after of the chassis rebuild.
First the topside:
And the underside:
Not much difference on the bottom except for the new AC power cord and the new fuse. I even restuffed the old caps with new ones and hot glued the ends...
Many thanks to all for the help - I wouldn't have been able to do this on my own!
(This post was last modified: 09-18-2014, 08:31 AM by EricS.)
RE: Need help restoring my 40-180 - SUCCESS - by EricS - 09-18-2014, 08:29 AM
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
