Need help identifying electrolytics
The schematic shows all four caps are grounded. Does your cap can have color code on the bottom where solder tabs are? Usually color dot next to lug. I recently did a 16b and I put a piece of tape on each wire with what color dot/ lug they went to. Really helped when I was ready to resolder after restuffing can.
RE: Need help identifying electrolytics - by KCMike - 09-18-2014, 06:05 PM
