What Model is this?
I wonder why the gallery picture has a smaller control panel? You can even see where the trim is notched out for the top of the escutcheon compared to the extra trim raised well above the dial cutout in the first picture.
What Model is this? - by quartermoonpro - 09-17-2014, 03:04 PM
RE: What Model is this? - by Warren - 09-17-2014, 07:02 PM
RE: What Model is this? - by klondike98 - 09-17-2014, 08:01 PM
RE: What Model is this? - by quartermoonpro - 09-17-2014, 08:31 PM
RE: What Model is this? - by Ron Ramirez - 09-17-2014, 10:16 PM
RE: What Model is this? - by tab10672 - 09-18-2014, 06:14 PM
RE: What Model is this? - by quartermoonpro - 09-18-2014, 09:18 PM
RE: What Model is this? - by sam - 09-18-2014, 11:03 PM
RE: What Model is this? - by quartermoonpro - 09-19-2014, 10:20 PM
RE: What Model is this? - by mikethedruid - 09-21-2014, 06:36 PM
RE: What Model is this? - by quartermoonpro - 09-23-2014, 12:24 PM
There are currently 4902 online users. [Complete List]
» 3 Member(s) | 4899 Guest(s)
