Need help identifying electrolytics
Well what I did was trace each wire from the lug to where it goes to on the schematic. If you look at schem. one goes to the 77 1st. audio. You will see that it is connected to the screen grid.
As you can see that is a1uf cap.
Do each one and make note of the value in relation to color on the can.
I do believe the 2 blues on mine were the 1ufs.
Hope this helps you.
RE: Need help identifying electrolytics - by KCMike - 09-18-2014, 06:37 PM
There are currently 10342 online users. [Complete List]
» 3 Member(s) | 10339 Guest(s)
