Philco 116x speaker
There is a place called Freeman Tuell speaker service in Dallas tx, they do excellent work on speaker reconing. I use them when I need that done on my antique radio speakers. Very reasonable prices . Call them at 214 324 1132
Philco 116x speaker - by Ronin61 - 09-16-2014, 10:02 PM
RE: Philco 116x speaker - by ccomer1955 - 09-16-2014, 11:52 PM
RE: Philco 116x speaker - by morzh - 09-17-2014, 07:39 AM
RE: Philco 116x speaker - by Arran - 09-18-2014, 12:11 AM
RE: Philco 116x speaker - by Fred Taylor - 09-18-2014, 07:46 PM
RE: Philco 116x speaker - by Ronin61 - 09-18-2014, 09:31 PM
There are currently 3056 online users. [Complete List]
» 1 Member(s) | 3055 Guest(s)
