Can anyone identify this Pilot radio?
Hello BrendaAnn,
I've checked my usual sources, but can't find this one. What does it do for a speaker? It appears that there is less here than meets the eye! Icon_e_wink What tubes are in the radio? 8 tubes for a broadcast band radio seems like a lot unless it is a radio/phono combo or it is part of a PA system. Also, I can't recall ever seeing a radio that tunes right to left, i.e., high portion of the band on the left. Interesting. Joe
Joe
RE: Can anyone identify this Pilot radio? - by Joe Rossi - 09-18-2014, 09:54 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3500 online users. [Complete List]
» 3 Member(s) | 3497 Guest(s)
