Can anyone identify this Pilot radio?
Possibly a Pilot T-1584, Vol 11 of Riders. The T-1684 is the same electronically but has push-button tuning. Joe
Joe
RE: Can anyone identify this Pilot radio? - by Joe Rossi - 09-18-2014, 10:18 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3525 online users. [Complete List]
» 3 Member(s) | 3522 Guest(s)
