OIL OR WATER STAIN??
I've done research since I posted this question on oil or water based stains. It seems they did use some sort of colored lacquer spray on these 1950's units. When I used a gel type paint remover and a scraper, it produced a blondish colored yucchy slurry - so all the paint must have been sitting on top of the wood. I don't know how possible it will be to duplicate tinted lacquer process - so I'm going to stain it and it seems that a water based stain is less smelly, less toxic and better to use on wood that has already been painted or stained. Will post a pic when I'm done. thanks
OIL OR WATER STAIN?? - by ODPILOT - 09-19-2014, 06:42 PM
RE: OIL OR WATER STAIN?? - by Warren - 09-19-2014, 10:04 PM
RE: OIL OR WATER STAIN?? - by jerryhawthorne - 09-20-2014, 01:45 AM
RE: OIL OR WATER STAIN?? - by ODPILOT - 09-20-2014, 09:41 PM
RE: OIL OR WATER STAIN?? - by Warren - 09-20-2014, 10:38 PM
There are currently 6220 online users. [Complete List]
» 3 Member(s) | 6217 Guest(s)
