Barn Fresh Apex 46
The U.S. Apex lowboy does compare favorably well to the 1929 Philco lowboy cabinets. One thing I love about the Philco lowboys is that the legs seem to be rather well attached, even though they lack a stretcher, I have yet to fine one with much wobble in the legs. The Apex has also faired well leg-wise, with very little wobble and the whole cabinet is still pretty solid. Turns out they also made a type 48 chassis that went in this same cabinet that had an extre type 24 tube, bringing it up to 8 tubes grand total. Seems to be as high as U.S. Apex went during the 1929-1930 period.
Barn Fresh Apex 46 - by Jayce - 09-20-2014, 05:23 PM
RE: Barn Fresh Apex 46 - by KCMike - 09-20-2014, 05:32 PM
RE: Barn Fresh Apex 46 - by Arran - 09-21-2014, 02:33 AM
RE: Barn Fresh Apex 46 - by Jayce - 09-21-2014, 12:37 PM
RE: Barn Fresh Apex 46 - by Arran - 09-22-2014, 12:54 AM
RE: Barn Fresh Apex 46 - by Jayce - 09-22-2014, 11:14 PM
RE: Barn Fresh Apex 46 - by OldRestorer - 09-23-2014, 08:05 PM
RE: Barn Fresh Apex 46 - by Jayce - 09-23-2014, 09:09 PM
RE: Barn Fresh Apex 46 - by Arran - 09-24-2014, 12:10 AM
RE: Barn Fresh Apex 46 - by Jayce - 09-24-2014, 12:20 PM
The speaker table error?
Philco 70 antenna lead
