Early Philco ID
Chuck, he's already described a 1929 Philco lowboy perfectly..the clam-shell grille opening is a dead giveaway. Plus 8 tubes with Type 245 outputs...that can only be a Model 87.
Icon_mrgreen
Early Philco ID - by joeinri - 10-23-2008, 07:53 PM
Re: Early Philco ID - by Ron Ramirez - 10-23-2008, 08:54 PM
Re: Early Philco ID - by Chuck Schwark - 10-23-2008, 08:54 PM
Re: Early Philco ID - by Ron Ramirez - 10-23-2008, 10:28 PM
Re: Early Philco ID - by joeinri - 10-24-2008, 08:45 AM
