Philco 116B
Congratulations on that find and a safe trip back home. I know you will do a good job restoring this one.
I have wanted one for years but never seem to find one that I can get shipped here.
Be sure and give us updates on the restoration!
Joe
Philco 116B - by Radioroslyn - 09-21-2014, 03:58 PM
RE: Philco 116B - by sam - 09-21-2014, 04:09 PM
RE: Philco 116B - by Radioroslyn - 09-21-2014, 05:45 PM
RE: Philco 116B - by Joeztech - 09-21-2014, 07:09 PM
RE: Philco 116B - by Radioroslyn - 09-21-2014, 07:29 PM
RE: Philco 116B - by Ron Ramirez - 09-21-2014, 09:37 PM
RE: Philco 116B - by thirtiesradio - 09-22-2014, 02:21 AM
RE: Philco 116B - by Radioroslyn - 09-22-2014, 10:24 AM
RE: Philco 116B - by Ron Ramirez - 09-22-2014, 10:44 AM
RE: Philco 116B - by morzh - 09-22-2014, 11:21 AM
RE: Philco 116B - by OldRestorer - 09-23-2014, 07:59 PM
There are currently 7076 online users. [Complete List]
» 2 Member(s) | 7074 Guest(s)
