Philco 116B
Oh...you have the late version 116B. In that case, kindly ignore my comments about the toner. You didn't specify and I made an incorrect assumption. Oops.
Well, you don't see as many late version 116Bs as early shouldered 116Bs, anyway. And the late version still sounds good even with a smaller speaker (8 inch in the late version vs. 10-1/2 inch in the early version).
Hopefully you can manage to hide the hole as best as possible.
Philco 116B - by Radioroslyn - 09-21-2014, 03:58 PM
RE: Philco 116B - by sam - 09-21-2014, 04:09 PM
RE: Philco 116B - by Radioroslyn - 09-21-2014, 05:45 PM
RE: Philco 116B - by Joeztech - 09-21-2014, 07:09 PM
RE: Philco 116B - by Radioroslyn - 09-21-2014, 07:29 PM
RE: Philco 116B - by Ron Ramirez - 09-21-2014, 09:37 PM
RE: Philco 116B - by thirtiesradio - 09-22-2014, 02:21 AM
RE: Philco 116B - by Radioroslyn - 09-22-2014, 10:24 AM
RE: Philco 116B - by Ron Ramirez - 09-22-2014, 10:44 AM
RE: Philco 116B - by morzh - 09-22-2014, 11:21 AM
RE: Philco 116B - by OldRestorer - 09-23-2014, 07:59 PM
There are currently 7681 online users. [Complete List]
» 3 Member(s) | 7678 Guest(s)
