Zenith 5S319 racetrack and AK 84 question
My set has that photo finish stripe on the right side. There are many sets being advertised without it. Does it mean production change or just a simple removal of it during the cabinet stripping and restoring? Also, has any of AK-84s come with a cabinet side switch? Thanks.
Zenith 5S319 racetrack and AK 84 question - by fields 100 - 09-22-2014, 01:08 PM
The speaker table error?
Philco 70 antenna lead
