speaker for 16B Cathedral
Other models that used the K-17 speaker were 14B, 17B,18B and 118B. You could also use a K-7, K-21, or a K-22 and probably a few others but you would have to replace the output transformer with one designed for push-pull output and disconnect the bucking coil.
M R Radios   C M Tubes
speaker for 16B Cathedral - by SteveJB - 09-22-2014, 03:57 PM
RE: speaker for 16B Cathedral - by fields 100 - 09-22-2014, 07:44 PM
RE: speaker for 16B Cathedral - by Steve Davis - 09-23-2014, 09:33 AM
RE: speaker for 16B Cathedral - by SteveJB - 09-23-2014, 12:55 PM
RE: speaker for 16B Cathedral - by Steve Davis - 09-23-2014, 02:27 PM
RE: speaker for 16B Cathedral - by Mondial - 09-23-2014, 03:00 PM
RE: speaker for 16B Cathedral - by Steve Davis - 09-23-2014, 04:59 PM
RE: speaker for 16B Cathedral - by Mondial - 09-23-2014, 09:16 PM
There are currently 9938 online users. [Complete List]
» 3 Member(s) | 9935 Guest(s)
