Output Transformer for Model 41-300
I just started working on a 41-300 and came across this thread when I found that the primary on my output transformer is also open.  In addition to the use of a Hammond HX-125D as a replacement would this Edcor also be suitable?  see/www.edcorusa.com/gxpp10-4-10k.  The Edcor is less costly.  Does anyone have any experience with the Edcor products?  Regardless of which one is used I will need some guidance on working around the secondary feedback tap referred to earlier in this thread.
Thanks, Bob
Output Transformer for Model 41-300 - by hyounce - 08-31-2010, 11:48 PM
RE: Output Transformer for Model 41-300 - by rck46 - 09-23-2014, 06:17 PM
