Philco 630B Tombstone
Okay...what is "PTSD"?
You can see a picture of my 650B in the "Philco Cabinet Restoration" section, under the topic "Model 650B Tombstone Project."
Philco 630B Tombstone - by Guest - 11-25-2005, 01:08 PM
[No subject] - by Ron Ramirez - 11-25-2005, 01:46 PM
[No subject] - by Guest - 11-25-2005, 04:00 PM
[No subject] - by Ron Ramirez - 11-26-2005, 06:35 PM
[No subject] - by Guest - 11-26-2005, 09:25 PM
[No subject] - by Ron Ramirez - 12-15-2005, 12:02 PM
[No subject] - by Guest - 12-15-2005, 07:04 PM
[No subject] - by Ron Ramirez - 12-15-2005, 08:26 PM
[No subject] - by Ron Ramirez - 12-16-2005, 12:35 PM
[No subject] - by Guest - 12-17-2005, 01:49 AM
[No subject] - by Chuck Schwark - 12-17-2005, 11:08 AM
[No subject] - by Guest - 01-02-2006, 04:41 AM
[No subject] - by Ron Ramirez - 01-02-2006, 11:20 AM
Philco 91 Tuning Condenser
There are currently 9939 online users. [Complete List]
» 2 Member(s) | 9937 Guest(s)
