655 SW band
I've got this set 90% restored electrically, but am having one last issue with it. The SW band will not track at the bottom, no matter what I do with the adjustments. It gets as close as I can get it (6 MHz shows as 6.2 MHz on the dial) with the lower end compensator cap pretty much fully open. The high end tracks pretty well, down as far as about 8 MHz or so, then gets progressively more off.
Any ideas?
TIA
655 SW band - by BrendaAnnD - 09-25-2014, 10:44 AM
RE: 655 SW band - by morzh - 09-25-2014, 10:49 AM
RE: 655 SW band - by Chuck Schwark - 09-25-2014, 01:13 PM
RE: 655 SW band - by morzh - 09-25-2014, 02:42 PM
RE: 655 SW band - by Chuck Schwark - 09-25-2014, 02:51 PM
RE: 655 SW band - by BrendaAnnD - 09-26-2014, 10:28 AM
RE: 655 SW band - by AI2V - 09-26-2014, 12:47 PM
RE: 655 SW band - by Chuck Schwark - 09-26-2014, 01:11 PM
fine post - by waseem123 - 09-30-2014, 04:00 AM
There are currently 7003 online users. [Complete List]
» 1 Member(s) | 7002 Guest(s)
