655 SW band
Brenda
I had similar problem with 38-15, happened to be the pentagrid.
Have you tried to change the osc tube yet? The 6A7?
655 SW band - by BrendaAnnD - 09-25-2014, 10:44 AM
RE: 655 SW band - by morzh - 09-25-2014, 10:49 AM
RE: 655 SW band - by Chuck Schwark - 09-25-2014, 01:13 PM
RE: 655 SW band - by morzh - 09-25-2014, 02:42 PM
RE: 655 SW band - by Chuck Schwark - 09-25-2014, 02:51 PM
RE: 655 SW band - by BrendaAnnD - 09-26-2014, 10:28 AM
RE: 655 SW band - by AI2V - 09-26-2014, 12:47 PM
RE: 655 SW band - by Chuck Schwark - 09-26-2014, 01:11 PM
fine post - by waseem123 - 09-30-2014, 04:00 AM
