  • 1 Vote(s) - 3 Average
01A rejuvenation with a battery set?
Has anyone tried to rejuvenate 01A tubes using a battery set to apply voltage to the filaments? I was reading on a different, and inferior, forum that 15 minutes or so at about 6.3 volts can help marginal tubes.
I have also read that the process doesn't work as well on some manufacturers. My Freed Eismann NR-6 has a set of WARDS 01a tubes that measure in the low acceptable to low marginal range on my Triplett 2314.
So, the idea was to apply 6.3 measured at the filament pins with no other voltage on the set. Can someone explain why this is a horrible idea?
Don't worry, it is just a mental exercise.
Charlie in San Antonio
01A rejuvenation with a battery set? - by ccomer1955 - 09-25-2014, 02:06 PM
91H Code 126 Restore
There are currently 2670 online users. [Complete List]
» 1 Member(s) | 2669 Guest(s)
