ZENITH chassis 1004
Hello.I ju8st purchased a zenith 1004 chassis.First i replaced all electrolytics and large caps.Then brought it up on my variac and worked fine.I then cleaned the volume pot and radio still worked.I then replaced the rest of the caps. and one resistor.Turned it back on and can only recieve 1 statio at around 1400 and at low volume.Rechecked all work,then checked tubes,variable cap. for bents plates or ground issues.Any suggestions would be appreciated.ron
ZENITH chassis 1004 - by theboyzz - 10-26-2008, 01:44 PM
Re: ZENITH chassis 1004 - by etech - 10-26-2008, 11:42 PM
Re: ZENITH chassis 1004 - by exray - 10-28-2008, 07:10 AM
Re: ZENITH chassis 1004 - by Texasrocker - 10-30-2008, 02:12 AM
Re: ZENITH chassis 1004 - by BDM - 10-30-2008, 01:47 PM
Re: ZENITH chassis 1004 - by exray - 10-30-2008, 07:12 PM
Re: ZENITH chassis 1004 - by BDM - 10-30-2008, 08:19 PM
Re: ZENITH chassis 1004 - by exray - 10-30-2008, 10:18 PM
Re: ZENITH chassis 1004 - by BDM - 10-30-2008, 10:22 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 3242 online users. [Complete List]
» 2 Member(s) | 3240 Guest(s)
