The best table top Philco
[Image: http://www.wa2ise.com/radios/philco401.jpg]Though not that sensitive, it does look cool, as it's unusual.
Or
[Image: http://www.wa2ise.com/radios/ph46-806.jpg] I got from Peru via ebay...
Or
[Image: http://www.wa2ise.com/radios/ph50_922.jpg] this is a classic.
The best table top Philco - by fields 100 - 09-19-2014, 08:24 AM
RE: The best table top Philco - by morzh - 09-19-2014, 09:30 AM
RE: The best table top Philco - by Eric Adams - 09-19-2014, 09:56 AM
RE: The best table top Philco - by morzh - 09-19-2014, 10:17 AM
RE: The best table top Philco - by Chuck Schwark - 09-19-2014, 10:21 AM
RE: The best table top Philco - by fields 100 - 09-19-2014, 11:14 AM
RE: The best table top Philco - by fields 100 - 09-19-2014, 11:20 AM
RE: The best table top Philco - by morzh - 09-19-2014, 12:43 PM
RE: The best table top Philco - by fields 100 - 09-19-2014, 01:02 PM
RE: The best table top Philco - by morzh - 09-19-2014, 02:17 PM
RE: The best table top Philco - by SteveJB - 09-19-2014, 06:21 PM
RE: The best table top Philco - by fields 100 - 09-19-2014, 08:12 PM
RE: The best table top Philco - by SteveJB - 09-20-2014, 06:56 PM
RE: The best table top Philco - by mikethedruid - 09-21-2014, 06:27 PM
RE: The best table top Philco - by tab10672 - 09-21-2014, 06:55 PM
RE: The best table top Philco - by dos0711 - 09-22-2014, 03:28 PM
RE: The best table top Philco - by Mondial - 09-22-2014, 06:21 PM
RE: The best table top Philco - by wa2ise - 09-25-2014, 11:44 PM
RE: The best table top Philco - by klondike98 - 09-26-2014, 09:14 PM
There are currently 7521 online users. [Complete List]
» 3 Member(s) | 7518 Guest(s)
