655 SW band
Brenda,
Just had another thought -- lead dress to that SW coil could be something to look at.
If there was previous "messing around" right there, wire routing could be compromised.
Maybe the leads to the SW coil are reversed?
Leads to the coil being a little too long can alter the inductance a bit as well.
Chuck
655 SW band - by BrendaAnnD - 09-25-2014, 10:44 AM
RE: 655 SW band - by morzh - 09-25-2014, 10:49 AM
RE: 655 SW band - by Chuck Schwark - 09-25-2014, 01:13 PM
RE: 655 SW band - by morzh - 09-25-2014, 02:42 PM
RE: 655 SW band - by Chuck Schwark - 09-25-2014, 02:51 PM
RE: 655 SW band - by BrendaAnnD - 09-26-2014, 10:28 AM
RE: 655 SW band - by AI2V - 09-26-2014, 12:47 PM
RE: 655 SW band - by Chuck Schwark - 09-26-2014, 01:11 PM
fine post - by waseem123 - 09-30-2014, 04:00 AM
There are currently 9665 online users. [Complete List]
» 3 Member(s) | 9662 Guest(s)
