116B vs 650B
With an extra stage of IF amplification, the 116 should have an edge over the 650 on all bands. That the 650 comes so close to 116 performance, especially on the BC band, seems quite amazing.
Maybe over the winter I'll find time to get my own 650B going. Icon_smile
Oh, and your 116B cabinet looks great!
116B vs 650B - by BDM - 10-20-2008, 09:53 PM
Re: 116B vs 650B - by etech - 10-21-2008, 08:59 PM
Re: 116B vs 650B - by BDM - 10-21-2008, 09:35 PM
Re: 116B vs 650B - by BDM - 10-26-2008, 10:31 PM
Re: 116B vs 650B - by etech - 10-26-2008, 11:46 PM
Re: 116B vs 650B - by BDM - 10-26-2008, 11:51 PM
Re: 116B vs 650B - by Ron Ramirez - 10-27-2008, 10:06 AM
Re: 116B vs 650B - by BDM - 10-27-2008, 10:10 AM
Re: 116B vs 650B - by Doug Houston - 10-27-2008, 04:45 PM
Re: 116B vs 650B - by BDM - 10-27-2008, 08:55 PM
Re: 116B vs 650B - by Texasrocker - 10-30-2008, 03:14 AM
Re: 116B vs 650B - by Doug Houston - 11-01-2008, 10:32 PM
Re: 116B vs 650B - by MinnesotaHam - 12-01-2008, 10:14 PM
Re: 116B vs 650B - by BDM - 12-05-2008, 10:35 PM
Philco 91 Tuning Condenser
