38-2670 cabinet problem
Hi Folks,
Have a problem with the veneer on the front corners on the radius's.
They have a vertical split on both corners that looks like it was caused by the wood underneath the veneer splitting. I think I could inject some glue or epoxy into the crack, and top it off with a colored wood filler, if I could open it up enough to get something in there.
I would then refinish both of those corner panels and leave the rest alone.
I am thinking if they were stained a darker maybe solid color and then sprayed with laquer it would be presentable?
Maybe a dark toner would be better?
Really don't want to try and replace the veneer on those 2 corner panels with that tight of a corner radius.
Maybe Kirk would know a good way to fix this.
It's a nice playing radio so I would like to finish it and find a sturdy shelf to display it on. Weighs a ton.
[Image: http://i1161.photobucket.com/albums/q509...crack1.jpg]
murf
[Image: http://i1161.photobucket.com/albums/q509...crack2.jpg]
38-2670 cabinet problem - by murf - 09-27-2014, 03:46 PM
RE: 37-675 cabinet problem - by sam - 09-27-2014, 04:25 PM
RE: 37-675 cabinet problem - by OldRestorer - 09-27-2014, 08:51 PM
RE: 37-675 cabinet problem - by OldRestorer - 09-28-2014, 03:07 PM
RE: 37-675 cabinet problem - by murf - 09-28-2014, 04:19 PM
RE: 38-2670 cabinet problem - by Arran - 09-30-2014, 09:47 PM
RE: 38-2670 cabinet problem - by murf - 10-01-2014, 08:02 PM
RE: 38-2670 cabinet problem - by murf - 10-03-2014, 06:18 PM
RE: 38-2670 cabinet problem - by Ron Ramirez - 10-03-2014, 06:37 PM
RE: 38-2670 cabinet problem - by PhilcoJohn - 10-03-2014, 07:25 PM
RE: 38-2670 cabinet problem - by murf - 10-03-2014, 09:31 PM
RE: 38-2670 cabinet problem - by Arran - 10-04-2014, 11:08 PM
RE: 38-2670 cabinet problem - by Eliot Ness - 10-05-2014, 07:52 AM
RE: 38-2670 cabinet problem - by Arran - 10-07-2014, 11:43 PM
RE: 38-2670 cabinet problem - by murf - 10-08-2014, 01:32 PM
RE: 38-2670 cabinet problem - by thirtiesradio - 10-09-2014, 12:38 AM
RE: 38-2670 cabinet problem - by murf - 10-26-2014, 03:01 PM
RE: 38-2670 cabinet problem - by sam - 10-26-2014, 03:29 PM
RE: 38-2670 cabinet problem - by Eliot Ness - 10-26-2014, 03:36 PM
RE: 38-2670 cabinet problem - by klondike98 - 10-26-2014, 03:46 PM
RE: 38-2670 cabinet problem - by thirtiesradio - 10-26-2014, 10:16 PM
RE: 38-2670 cabinet problem - by jerryhawthorne - 10-27-2014, 02:12 PM
There are currently 11056 online users. [Complete List]
» 2 Member(s) | 11054 Guest(s)
