116B vs 650B
Doug, great post. I'm going to pull it out to do a few other things. I'll test it in this manner also as you've stated.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
116B vs 650B - by BDM - 10-20-2008, 09:53 PM
Re: 116B vs 650B - by etech - 10-21-2008, 08:59 PM
Re: 116B vs 650B - by BDM - 10-21-2008, 09:35 PM
Re: 116B vs 650B - by BDM - 10-26-2008, 10:31 PM
Re: 116B vs 650B - by etech - 10-26-2008, 11:46 PM
Re: 116B vs 650B - by BDM - 10-26-2008, 11:51 PM
Re: 116B vs 650B - by Ron Ramirez - 10-27-2008, 10:06 AM
Re: 116B vs 650B - by BDM - 10-27-2008, 10:10 AM
Re: 116B vs 650B - by Doug Houston - 10-27-2008, 04:45 PM
Re: 116B vs 650B - by BDM - 10-27-2008, 08:55 PM
Re: 116B vs 650B - by Texasrocker - 10-30-2008, 03:14 AM
Re: 116B vs 650B - by Doug Houston - 11-01-2008, 10:32 PM
Re: 116B vs 650B - by MinnesotaHam - 12-01-2008, 10:14 PM
Re: 116B vs 650B - by BDM - 12-05-2008, 10:35 PM
Philco 91 Tuning Condenser
